IH 674
David Hutton
01-20-2003 10:34:46
I have an IH 674 - model # I674D-RC, with a front end loader. I loaned it to my brother and his son was apparently using it to ram stumps and small trees. Now it won't move forward or reverse except occasionally very slightly. May be my imagination but it seems to move better if the hydrolic lift is moved up and down. Can anyone suggest what the problem may be? Thanks.
David
01-23-2003 05:51:47
 Re: IH 674 in reply to David Hutton, 01-20-2003 10:34:46
I took the bottom plate (what I always called the gravel pan) off at the bottom of the bellhousing and couldn't see anything obvious wrong. The clutch looks good. One thing I don't know...should the throw-out bearing be tight against the pressure plate or should it spin freely if the clutch is NOT depressed? Thanks for the help
Max
01-22-2003 20:46:05
If it has the TA(Torque Ampilfier) then the transmission control valve may need resealing.
David Hutton
01-23-2003 05:46:16
 Re: Re: IH 674 in reply to Max, 01-22-2003 20:46:05
Max...Thanks for the suggestion...How do I determine if I have a torque ampilfier?
Max
01-23-2003 06:16:23
 Re: Re: Re: IH 674 in reply to David Hutton, 01-23-2003 05:46:16
It was a hi/lo shifter that can be shifted without the clutch.
David
01-23-2003 07:02:56
 Re: Re: Re: Re: IH 674 in reply to Max, 01-23-2003 06:16:23
No...I have to use the clutch to shift. Thanks
geok
01-20-2003 14:15:17
Sounds like he may have thrown the faces off the cluch (if equipped). If I remember correctly, there is a plate that can be unbolted on the bottom of the bell housing. Remove and inspect.
David
01-21-2003 05:55:09
 Re: Re: IH 674 in reply to geok, 01-20-2003 14:15:17
Thanks, Geok for the suggestion. Will try
