Info on TD 18
Jeff
03-19-2001 22:33:30
I recently found a TD 18 and was hoping someone could help me ID it a little better-- The numbers I have are TD 18 sn TDR 12924 T7BH -- The crawler starts on gas and then at warm up you mechanicly switch over to diesel-- It has a Bucyris-Erie blade-- If anyone can part with info on what series of crawler this is and when they were manufactered I would greatly appreciate it-- Thanx and happy trails(building)--- Jeff
hector gemme
02-10-2005 10:27:13
 Re: Info on TD 18 in reply to Jeff, 03-19-2001 22:33:30
HI I HAVE SOME TD18 USE PARTS
GEO
03-20-2001 18:27:05
Looks like a 1947 model, 88 HP weighs around 22,000 lbs. Nearly all TDs start on gas and then run on diesel. The heads are prone to crack between the valve seats. If the one you are looking at doesn't already have a cracked head it will most likely will have. You have to be real careful and watch the temp gauge and keep the radiator full to minimize the problem.
