JD 350 finals
Jim Horrocks
01-21-2003 14:45:15
Help! I have installed one of the finals on my JD 350, and I have made all of the adjustments called for in the manual. If I put crawler in first gear and reverser in forward position, I can still turn the flange axel shaft by hand. Is this correct, or should I not be able to turn the axels by hand without pulling back the steering lever?
Thanks,
Jim in Oregon
gatractorman
01-22-2003 02:27:54
 Re: JD 350 finals in reply to Jim Horrocks, 01-21-2003 14:45:15
If the engine is not running then yes you would be able to turn it, the reverser lever does nothing until the engine is running and builds pressure to engage either forward or reverse clutch pack.
Steve
01-22-2003 05:05:21
 Re: Re: JD 350 finals in reply to gatractorman, 01-22-2003 02:27:54
third party image
That is correct to a certain degree. However....If one sprocket hub turns the other should turn with it. If you have weight on the opposite side and the one side still turns then there is something wrong.
gatractorman
01-22-2003 13:19:29
 Re: Re: Re: JD 350 finals in reply to Steve , 01-22-2003 05:05:21
I think he only has one final drive on.
