843 bobcat hydro problem
Charlie
01-26-2003 22:50:39
I have 1994 843 bobcat my problem is in the boom mechanism. I'm not getting any down pressure, when the boom is up and I work the peddle it comes down just fine but when it reaches the ground it wont even pic the machine up. Any advice would be greatly appreciated.
gatractorman
01-27-2003 02:35:40
 Re: 843 bobcat hydro problem in reply to Charlie, 01-26-2003 22:50:39
Hey Charlie, Bobcat's with some age on them commonly had this problem and usually it was due to #1- old Coke bottles or dirt under the pedal restricting movement, or #2- linkage bushings worn to the point it wont work the spool the opposite way (do you have alot of play in the pedal?)or, #3- pushing pedal too far and going into float position. If none of these are the problem come on back and I'll give you more useless info. LOL
Charlie
01-27-2003 20:36:10
 Re: Re: 843 bobcat hydro problem in reply to gatractorman, 01-27-2003 02:35:40
Hey gatractorman, I tore down the left lift cylinder on a sper of the momment type deal, and to my supprise the nut at the end of the rod had backed completely off letting the piston slide off. This ofcorse caused severe damage to the piston,nut,and threads, but at least I know whats wrong. Thanx for all your help,Charlie
