BTD 6 Clutch
Jim
01-27-2003 11:40:23
Hi Guys:I'm about to replace main clutch plate on BTD 6 dozer...Do I need to move engine,or can I just get it from clutch housing area.Ser # 4129.Thanks.
AJ
01-28-2003 01:40:04
 Re: BTD 6 Clutch in reply to Jim, 01-27-2003 11:40:23
Yes you can,it will come out but has very little clearance,I used to take the air cleaner out of the way,lie on the bonnet to undo it,you got to take the grease nipple on the end of the shaft out,it is that tight of fit,use a string to hold up the centre plate when installing.
Good luck
AJ
hector gemme
02-09-2005 05:59:39
 Re: Re: BTD 6 Clutch in reply to AJ, 01-28-2003 01:40:04
HI I HAVE SOME TD6 PARTS
dennis anthony
03-03-2005 17:38:26
 Re: Re: BTD 6 Clutch in reply to hector gemme, 02-09-2005 05:59:39
have bought a td6 bullgrader. would like to know if you have parts for these. e-mail at dlainpick@yahoo.com. if possible would like to have a number so we can talk about parts needed. thanks
