BTD 6 Clutch
Jim
01-30-2003 02:28:03
Hi Guys.I posted a question recently about removing a main clutch from my BTD 6 dozer.I got it out OK , but installing it is proving difficult.Very tight fit...any ideas? Thanks again.
AJ
01-30-2003 08:33:47
 Re: BTD 6 Clutch in reply to Jim, 01-30-2003 02:28:03
Jim you got to put the whole assembly down into the housing in one lump,just have the adjuster ring screwed in a few threads,offer it up to the flywheel,you then have to get the shaft into the polit bearing,once you get the shaft to enter you are over the worst,it is 38 or 9 years since I did a six clutch and I seem to remember using a string to hold the centre plate up but can't remember where I tied it to,maybe someone else on the board might know.
AJ
Jim
01-30-2003 12:40:29
 Re: Re: BTD 6 Clutch in reply to AJ, 01-30-2003 08:33:47
A.J...Thanks again for the advice.I guess it's a matter of getting the angle of entry right.
I'll take more advice on this one,Guys.Thanx.
William Brener
02-20-2003 16:36:30
 Re: Re: Re: BTD 6 Clutch in reply to Jim, 01-30-2003 12:40:29
Make sure you have the three compression bolts tightened fully. Have the clutch assembeled with the coupling and adjuster ring all in place and it should slide right in. You have to put some sealer on the adjuster face that bolts onto the diff side first and then bolt it up first. Do the outer housing onto the outer sprocket drive next and then loosen the compression bolts. I have a photocopied manual and can send you the relevant pages by mail or email if I find a scanner.
William
