JD 350C
David
01-31-2003 09:55:45
I just purchased a JD 350C that has a plate that says JDT 303 350CE and Ser # 220524T. Can anyone tell me the year? I was told that the pads that bolt on the chain or rails should be bolted on so that the "ridge" is at the front of the pad. Is that correct. Thanks
Jafet Zapata
12-04-2003 15:55:57
 Re: JD 350C in reply to David, 01-31-2003 09:55:45
David, we have a 350C crawler and were interested in knowing the year. We went to a JD dealer and with the Serial Number they found the year, because they have a book to look that up. We hope this can be of help. Jafet
Jonathan
01-31-2003 14:47:37
...can't help with the year...thats usually not important...You just need the serial # and model to get parts.... As far as the track pads are concerned....the grouser bar should be forward on the pad as it travels over the top of the front idler...They don't bolt on in either direction...if they are to the rear of the pad, then the entire track chain is on the machine backward...
