Case 680 construction king backhoe and loader.
Raymond Joly
02-01-2003 07:46:26
Iam looking at a 680 case I was wondering if anyone knows anything about them. Information seems to be scarace on the 680. Thank You
Shovelman
02-02-2003 14:51:45
 Re: case 680 construction king backhoe and loader. in reply to Raymond Joly, 02-01-2003 07:46:26
Raymond,
Years ago, I had a 680CK, around a 1970 vintage. It was a great machine for me. I ran it many, many hours and had a few minor problems with it, but that is all.
It was heavy and somewhat slow, and it didn't get around in deep mud all that well, due to it being only 2WD. I sold it for more than I paid for it, and it made a lot of money for me while I owned it.
A couple of weak points: The lower swing pin on the hoe had a self-aligning plain bearing that gave me trouble on several occasions. When it would break, the swing pin would drop down and hit the rods on the swing cylinders, scoring them. I finally welded the retainer in place and that cured it.
The way the hoses were routed through the swing frame on the hoe tended to twist and chafe them, and I had to replace them on several occasions.
The machine always had low clutch pressure, but it never bothered. Also, It did not tolerate ether very well. The fellow who bought it from me over did it with the ether once and broke the ring lands on a couple of pistons. I think he was a little more careful after that!
Feel free to email or give me a call if you have any questions. My number is (860)738-2441.
Regards,
Scott Goff
Roy Ator
11-20-2003 18:54:57
 Re: Re: case 680 construction king backhoe and loa in reply to Shovelman, 02-02-2003 14:51:45
I have a 1979? case 680 Construction King Backhoe with a loader . I am having trouble with the engine. I used it about two months ago and it ran good. It has always had blow by but it wasn't bad after it got warm. my problem now is when I was done with it the last time I had used it about three hours using it normaly, not real hard, but working it. When I shut it off, it was running good. Now I try to start it and I can't get it to fire. It won't even fire using starting fluid. It won't even knock when I overload it with starting fluid.Any sugestions on what might be the problem It is sitting outside and I need to get it started to move inside, so I can make any repairs that are necessary. Any help would be appreciated
