IH500C fit a JD Hoe ?
Tim in Oregon
02-03-2003 08:44:56
third party image
I looked at a JD model# 51 ser# 6184 backhoe attachment this weekend. The mounting appears to mate up with my weight rack so I was wondering if it would fit my 500C? The guy said it was on a JD1010 he thought, the only thing I note was the lack of a seat, all the valving as well as quick disconnect were there. He wants $3000.00
Thanks,
Tim
Lee
05-06-2003 03:47:33
 Re: IH500C fit a JD Hoe ? in reply to Tim in Oregon, 02-03-2003 08:44:56
I paid $7000 for my 500c WITH an IH3142A hoe. someone else posted $1200, that is about right. For $3-4000, you could get a whole Ford 801 industrial tractor with a Pippin hoe, around here.
Taylor Lambert
02-05-2003 21:32:23
Im sure it could be mounted on your machine. I just put and older Ware hoe on a friends JD. Ware made alot of hoes that fit different crawler machines. Around here there mostly on Cat track loaders. Where are you located if your close to North Mississippi Ill take a look at it for you. Best reguards Taylor Lambert
Tim from Oregon
02-06-2003 11:25:57
 Re: Re: IH500C fit a JD Hoe ? in reply to Taylor Lambert, 02-05-2003 21:32:23
my machine is in central soouth Washington State so I'm a ways away from you...
Thanks
Tim
marlowe
02-03-2003 20:16:51
3000.00 for a 51 ?? way to much paid 1200.00 for the one i got and it's like new with a 24 and 30 in. bucket
Jonathan
02-03-2003 12:04:13
3000 dollars ???? is he sniffing glue ?????
