JD 350C problem
David Hutton
02-06-2003 06:32:51
I recently purchased a JD 350C with a 6-way blade and both hydraulic "rams" that tilt the blade forward and backwards have been busted and rewelded at the end. One is broken again ( I would guess the weld was poor). My questions are: Where can I find good used rams for sale and what should I pay? If I take them to a machine shop, can they fix them reasonably? Thanks for any advice.
Rob J
02-07-2003 09:38:37
 Re: JD 350C problem in reply to David Hutton, 02-06-2003 06:32:51
It's not worth buying new unless the ram is pitted and tearing up seals. Just bevel the edges and reweld them after checking alignment. They'll probably last another 5 years or better.
Rob
Bob/Ont
02-06-2003 06:56:14
Dave, I am not very familliar with your machine but if the rods are breaking a lot as yours seem to be doing, it might be the pivot points where your blade mounts are worn too much and the rods get a side load on them. Check this out and fix any problem here first before buying a lot of rods.
Later Bob
