350 JD-6-way Blade Clutch
Jim in Oregon
02-11-2003 08:32:13
I'm looking for info on the free travel for the main clutch. My crawler has a reverser. Also on the T-handle that controls the 6-way blade, when I tilt it all the way over to the stop, or raise it all the way up to the stop, it shoots hydrolic fluid out and runs down inside. I don't know where it's coming from, need to know if there is a safety on top or a by-pass and where it might be located.
Thanks,
Jim
chuck in Texas
02-12-2003 09:58:38
 Re: 350 JD-6-way Blade Clutch in reply to Jim in Oregon, 02-11-2003 08:32:13
my 350 b has a 6 way and theres some sort of popup valve on top of tank by filler cap that oozes fluid when i hit stops...that mite be where your leak is coming from although it sounds more like you got a busted hose...try lifting tank cover and operating blade to look for leak...some sort of face shield would be a good idea.
good luck
Lavoy
02-11-2003 16:15:14
Jim,
350 with reverser does not have a main clutch. Pedal is only hooked to a valve on the reverser.
Lavoy
Rob J
02-11-2003 11:24:31
Bypass is usally back into the return side. You can usually here the fluid shooting back into the tank. Rare cases the bypass valve can get stuck. It's simple, usually just a ball and spring.
Sounds like you just have a leak you need to track down.
Good Luck,
Rob
