Hauling a dead JD 350
Shawn
02-12-2003 19:25:24
This crawler has been sitting for a while. blade is down. Is it possible to haul it out. Are there companies that specialize in this?
Howard H.
02-19-2003 12:21:10
 Re: Hauling a dead JD 350 in reply to Shawn , 02-12-2003 19:25:24
Hi,
I picked one up just like you're facing a few weeks ago.
I hired a fellow with a local backhoe and he just pulled it up on my trailer. He had to work it back and forth some, but it wasn't too bad. I have steel ramps on back of my trailer and I oiled them and it just slid right on up there!
Good luck,
Howard H.
Jim In Oz
02-13-2003 03:27:08
You can try a Tilt Tray truck ( with winch )...It will pull the old thing onto it's tray , no problems.Neutralize trans,float blade & pull it on backwards.No drama.
chuck in Texas
02-12-2003 20:40:38
you should be able to jack blade up with a high lift farm jack while somebody pulls back on joystick...as long as hydraulics in fairly good shape blade will stay up till u load it...i'd be more worried about tracks being stuck.
i've got a 350b and it pulls pretty easy behind a 62 ford 2000 tractor...i dont know how far you gotta haul it but a 1 ton truck and heavy duty trailer will work.
good luck
