125B case excavator
Clyde Campbell
02-14-2003 08:21:02
Please help! I have a 125B Case excavator serial 74313. When I use the lift boom, reach boom, or curl the bucket it will lug the engine down till it dies; even with no load in the bucket. If the tracks are moving the bucket and booms work fine. The tracks only have only have one speed (low) will not go to higher speed.
Thanks
Clyde
Ola Leger
01-28-2004 15:57:01
 Re: 125B case excavator in reply to Clyde Campbell, 02-14-2003 08:21:02
I im looking for a swing motor for a 125B case 1986, 1987, 1988, 1989, or 1990 from : Ola Leger phone number: (506)577-6460 cell: (506)533-0723
Jim Gerritsen
08-30-2004 13:24:56
 Re: Re: 125B case excavator in reply to Ola Leger , 01-28-2004 15:57:01
We are looking for sources that have junked machines: 125B Case Excavator machines.
We need parts for our Case 125B excavator: 1)track adjuster spring # 6546273
2) Cylinder assembly track adjustment # P6546277
Jim Gerritsen
Wood Prairie Farm
(800)829-9765
Bridgewater Maine
Ron
07-17-2003 00:54:01
You should check your hydraulic pump, seems to me the pump is not destroking/ swash plate hanging up.
Or regulater valve on the pump not working
Dave Grubb
02-14-2003 14:28:12
This is a real shot in the dark since I don't know how your machine is plumbed but do you have a filter in the common return line ahead of the tank?
I also suspect you may have a relief value not working or your engine is real weak. In any event your eangine should not stall.
Clyde Campbell
02-18-2003 06:49:03
 Re: Re: 125B case excavator in reply to Dave Grubb, 02-14-2003 14:28:12
Dave; The only filter I can find is in the tank and I have replaced it. This did not help. The machine seems to have plenty of power as long as I hold the foot pedals down making the tracks move while I work the booms or bucket.
anthony
04-17-2003 16:44:31
 Re: Re: Re: 125B case excavator in reply to Clyde Campbell, 02-18-2003 06:49:03
i have a 1988 case125b all hydralic stop working and start up every 10 an 1/2 hour with full tank of hydralic fuild help please
