Nat
02-15-2003 09:15:52
Re: Hauling a fullsize TLB, what to use? in reply to Gary, 02-14-2003 09:14:51
I am not speaking for the whole country, just here in NC.I have checked this pretty good and CDL means comercial. if you haul anything for your own use, (read not for comercial use), a CDL is not required, if for rent or for hire, or you work for someone else, it is a whole different game, I haul a trailer that has no rating stamped on it, and haul a 863 Bobcat,it and trailer weigh 11,000 lbs. NC law requires a class A endorcement on regular lic. truck and trailer weigh less than 26001lbs. A class B endorsement allows 56,000 in a straight truck,without CDL, if for your own use such as farm, but if you are for rent or hire a CDL is required so if over 26001 lbs, and doing comercial work a CDL is required, if trailer and truck are under 26001lbs, yet trailer is over 10000lbs, and doing comercial work a CDL is not required, but class A is required, man this post got long, hope it helps someone, but I'd still chack with the dept, of motor vech. anyway
