Holy cow...
chuck in Texas
02-19-2003 14:41:36
just got my manuals in...all of a sudden price JD wants for steering clutch job dont sound too bad.
any shortcuts suggested? deal on pulling tool box and hyd tank and fuel tank...is it possible to do job with them in place...i can see having side boxes off would aid in access with chain hoist to remove finals but theres gotta be another way...what about long studs and slide final out so you can sit it on a floor jack or something...about what does that casing weigh [final]...not sure if i'm reading right but does entire side frame have to be removed to get finals out? sorry to have so many questions but manual kinda surpised me. 70 350b thanx
chuck
chuck in Texas
02-20-2003 10:01:48
 Re: holy cow... in reply to chuck in Texas, 02-19-2003 14:41:36
thanx everybody...i'm sure i'll have more questions when i start tearin it down so this is fair warnin ;)
JD in victoria,tx wanted 1100 labor and 1700 parts...when i mentioned i had seen parts for less than half that elsewhere he said he'd use my parts but he wouldnt stand behind labor at all...even if they screwed up puttin parts in...i was born at nite...but it wasnt last nite ;)
Steve B
02-20-2003 05:28:48
Chuck, I did the same job last year, same machine. I made a JIG out of 1/2" bar bent int a "U" w 2 3 or 4 " legs bent at the bottoms. These will slide into the front of the final. There are 2 holes that they go into. I would recommend getting a torch w/ a rosebud tip to heat up those final bolts "they are very big and tight". They will come out easier with heat. You will need a good 3/4" drive socket set. Get some various sizes of steel plate, bars and rods. You can use these to help in knocking out the brake/ clutch arm from through the hole under the seat. Make sure you replace the Quill o ring inside the clutch housing. This is what usually leaks hydro fluid into the housing contaminating your brake band and clutch discs.
Pete/ME
02-20-2003 03:37:24
I jacked up the back end...block of wood between the drawbar and rear casting. Removed bolts from final and replaced four of them with 18" threaded rods...some grease and a cheap floor jack...and rocked them out. No problemo.
gatractorman
02-20-2003 02:30:45
I never had to remove the tanks when doing steering clutches on a 350, just get creative with a hoist. How much does JD get now for a clutch job? May need to adjust my price.
Lavoy
02-19-2003 19:22:22
Chuck,
Should be no reason to remove side rail. Probably do not need to remove fuel tank either, but if you are doing both sides, the fuel tank and boxes will lift off as one unit, not that many bolts, so consider time to remove boxes and tank versus smashed knuckles/hurt pride by fighting underneath them.
Lavoy
chuck in Texas
02-19-2003 20:10:00
 Re: Re: holy cow... in reply to Lavoy, 02-19-2003 19:22:22
looks like i better get 911 on speed dial..P/O welded/bolted later ROPS on...welded to blade frame and side steps...i'm talkin SERIOUS beads...i guess i should fix it now since i cant get to hose fittings under step treads cause i KNOW as soon as i get clutches fixed them other hoses gonna go :(
hmmmmm...i think my ins paid up...maybe...no...think i'll go argue with myself awhile ;)
thanx
chuck
Lavoy
02-20-2003 17:21:56
 Re: Re: Re: holy cow... in reply to chuck in Texas, 02-19-2003 20:10:00
In that case, disregard my previous idea.
Idea #2: Lots of alchohol(the drinking kind), several friends dumb enough to fall for the old FREE BOOZE trick, and a long weekend.
Lavoy
dick
02-19-2003 17:30:01
hi chuck. I also have a jd350. may be facing same job your are.my garage is to small for crawler,there for l will have to use chain fall on tree limb,if you come up with any short cuts,let us know. thanks dick
