JD 350C brake lever adjustment
David
02-20-2003 13:38:11
My JD 350C brake (clutch?)levers seem to work fine by stopping the track when I pull back on either one. However, I noticed that the right lever travels only about 1-2" before engaging while the right one travels 5-6" before it engages. Seems to me they both should have the same travel but I don't know. Can anyone tell me if I have a problem? If so, what should I do to correct it? Thanks in advancefor any advice.
David
03-02-2003 08:06:32
 Re: JD 350C brake lever adjustment in reply to David, 02-20-2003 13:38:11
Thanks for the advice. I appreciate you taking time to help me.
David
Clunkhead
03-02-2003 05:20:53
Dave it is a remote possibility that the clutch has been replaced without setting the arm hts.
If that is the case you want be able to adjust the detent linkage enough anyway, its a rare occurance but have seen it before. A longer threaded rod can bring it closer but its a temp fix till you can service the fianl clutch assembly properly. Do yourself a favor and follow the adjustment proceedure carefully in the manual and go from there.
Doug
02-20-2003 14:16:25
Clutches and brake band's need adjusting Not a hard procedure if you have manual, I can scan the pages you need if you don't have acess to a manual. Let me know if I can Help
David
02-21-2003 05:50:38
 Re: Re: JD 350C brake lever adjustment in reply to Doug, 02-20-2003 14:16:25
Doug,
Thanks so much for the info...Yes, I would be grateful for the scanned pages regarding how to adjust the clutch and brake bands. Thanks again.
david.hutton@netxv.net
Bib overalls
02-21-2003 16:45:34
 Re: Re: Re: JD 350C brake lever adjustment in reply to David, 02-21-2003 05:50:38
Hey david take the seat off and unturn the cap of the adj. needed brake and give it a few clicks, you really dont need a manual to do this.
