530 Case Backhoe
Doug
02-20-2003 15:23:05
Can anyone tell me how much Oil including filter an old 530 Case backhoe should hold I don't know if my dipstick is right or not it has an 188 Diesel engine. Thanks
Scott
02-22-2003 18:16:27
 Re: 530 Case Backhoe in reply to Doug, 02-20-2003 15:23:05
Just looked in the owner's manual for mine and it says if the filter is changed, add 5 quarts and run the engine then re-check it after the engine has been off long enough for the oil to return to the sump. Add oil to the full mark on the dipstick.
Steve M
02-22-2003 07:37:16
My case 480 backhoe has a 188D engine it holds 5 qts.
Ric
02-20-2003 16:23:46
The 188 in my 450 dozer holds 7 qts with a new filter. Do not know if the same as your backhoe???
Doug
02-20-2003 16:36:29
 Re: Re: 530 Case Backhoe in reply to Ric, 02-20-2003 16:23:46
I put the 188 out of a 530 backhoe in my 450 case dozer and the oil pan's are made different accordint to dip stick it only holds 5 qts with filter and I don't think that is right.
