International TD8-B
Taylor Marret
02-21-2003 07:44:22
Yes it is a B model dozer with a single lift cylinder on the front like a terex. It is made in Britian but that is all I know about it. Please help me find out any thing because if it is not too odd I plan to buy it. The serial # is41002B000757-X
raccoonparkok
01-10-2006 09:28:05
 Re: International TD8-B in reply to Taylor Marret, 02-21-2003 07:44:22
My father had a td8 International bulldozer. I helped start it up and run it in the 80's. I was talking to someone about the way it started up with gasoline and when you pulled down on a lever, it changed the compression in the cylinders, and changed to diesel. It didn't have glow plugs because running on gas warms it up enough to run on diesel. The guy said it has a pony motor or only ran gas on 2 cylinders. That is not how my dad said it worked. Does anyone know what I am talking about???
Milton
02-21-2003 11:20:04
Hello Taylor Marret, ---21 / Feb. / 2003 ---
Your British made "International BTD-8" SERIAL NUMBER 41002B000757-X was made in 1961.
SERIAL NUMBERS are as follows;
1960 ---- 501 to 603 1961 ---- 604 to 1082 1962 --- 1083 to 1700 1963 --- 1701 to 2320 1964 --- 2321 to 2862 1965 --- 2863 to 3636 1966 --- 3637 to 3793
This is all that I have on the "International BTD-9".
Regards, Milton -- E-Mail "farmall28@yahoo.com"
Brian Duncan
05-03-2003 15:58:19
 Re: Re: International TD8-B in reply to Milton, 02-21-2003 11:20:04
I am trying to identify An International dozer with the serial #TDCB24705T7CG or CC at the end I think its a TD-8. What year I don't know. Any help would be great. Thanks.
pukeko
03-02-2003 18:44:34
The BTD8,s wereolder than yours,with a 281 indirect injection diesel with glowplugs.I think yours sounds like a TD8B,made in Britain with the single hydraulic cylinder(theBTD8 had two)using the german engine239 cu,ins.direct injection.This series is a lot newer than the serial numbers described by Milton.
James Ledbetter
04-18-2003 12:42:43
 Re: Re: Re: International TD8-B in reply to pukeko, 03-02-2003 18:44:34
I have a BTD8 IH it has a 281 diesel it was made in Britain . I need a head gasket set for it, can anyone tell me where i can find one. model#BTD8782 serial#5076
James Ledbetter
04-18-2003 12:39:49
Milton
03-08-2003 07:31:36
pukeko, --- 8 / March / 2003 ---
The next IH crawler that I have listed (made in England by IH) is just listed as "TD-8". SERIAL NUMBERS for the TD-8 are;
1966 ---- 3794 to 4126 1967 ---- 4127 to 4403 1968 ---- 4404 to 4751 1969 ---- 4752 to 5010 1970 ---- 5011 to 5289 1971 ---- 5290 to 5385 1972 ---- 5386 to 5539 1973 ---- 5540 to 5849 1974 ---- 5850 to 6129 1975 ---- 6130 to 6226
I DO NOT have a listing for a "TD-8B" crawler.
Maybe somebody has a listing for that crawler.
Regards, Milton
