Cat engine
Bill R.
02-23-2003 12:57:11
The tag on the block reads 8T-8081 its out of motor grader. Is that the motor # or the Machine #? Is it a 318 or what? Any help would be appreciated LOL Bill
Kelly
02-24-2003 19:12:25
 Re: cat engine in reply to Bill R., 02-23-2003 12:57:11
Bill R,
8T-8081 would be a 1951 #12 blade, that engine is almost bullet proof.
Deas Plant.
02-23-2003 22:59:23
Hi, Bill. For a lotta years the same motor went into the Cat 12 graders and the D6 crawlers and you couldn't beat either to death with any amount of hard work. Even in the graders at flat out down the road, the pistons still only go up and down in time with the telegraph poles. They would lug down and keep pulling like VERY FEW other engines I have ever come across and that's been a few.
Later versions of the Cat. 12 engines in the 21F series machines used to break crankshafts at the second main bearing journal -- not often enough for it to be common knowledge amongst operators but several servicemen/repairers that I spoke to said it did happen from time to time, always on that second main journal. For whatever reason, it apparently did not occur in the older engines.
Treasure that little darlin', Mate.
You have a wonderful day. Best wishes. Deas Plant.
Bob/Ont
02-23-2003 18:12:58
Bill the D318 6 cyl was used in the older graders. Does it have a 2 cyl opposed starting engine on the back of it? Don't have a serial# book here to check for you.
Bill R
02-23-2003 20:37:31
 Re: Re: cat engine in reply to Bob/Ont, 02-23-2003 18:12:58
Bob Yes it has starting engine 2 cyl Bill
Bob/Ont
02-23-2003 22:34:34
 Re: Re: Re: cat engine in reply to Bill R, 02-23-2003 20:37:31
If it's got one spark plug on each side you got a D318 Bill. That's a long life engine, they will be going long after we stop:<)
Later Bob
Bill R
02-24-2003 08:13:45
 Re: Re: Re: Re: cat engine in reply to Bob/Ont, 02-23-2003 22:34:34
Bob
We have this old cat 12 grader that a buddy ran low on oil and stacked a rod bearing and ruined the crankshaft. I have heard about an engine that came out of a cotton gin. I'm going to look at it this week. The kid said it was the same engine was running and been in a barn under tarp a few years. Hope its the same can get it for scrap iron price. Thanks for your help Bill
