Cleaning out steering clutches on a jd 350
Rob J
02-24-2003 09:49:06
Someone posted a while back on how to clean the steering clutch area under the seat. I'm sure we have some leaks, crud and stuff in there. Something like Gunk and a pressure washer but there was something else used to flush out the water to prevent corrosion.
Thanks,
Rob
chuck in Texas
02-25-2003 05:36:43
 Re: Cleaning out steering clutches on a jd 350 in reply to Rob J, 02-24-2003 09:49:06
i'm not real sure i follow on what you wanna clean...if its just the area below the seat...have at it with a pressure washer...if its inside the housings that you adjust steering clutches and brake bands...i dont think i'd do anything in there except maybe pull drain plugs and hose it down with brake clean...ooops...wrong choice of words...spray liberally with brake clean in the aresol can...if that doesnt clean out the crud...u mite as well hold off until its time for clutches and bands.
