HD16
TR in IA
02-27-2003 10:29:29
Is anyone familiar with an HD16DP. I have on pushing oil out of the torque converter housing around the driveshaft. I have been told the is a scavenge pump that could be bad or seal rings broke on converter shaft. Any other choices?
hector gemme
02-10-2005 12:09:30
 Re: HD16 in reply to TR in IA, 02-27-2003 10:29:29
HI IHAVE SOME HD16 USE PARTS
Deas Plant.
03-01-2003 18:30:42
Hi, TR. There may also be a breather on the torque converter housing. If there is, check to see if it is clean and allowing the housing to 'breathe'. If there is one that is not working, this could cause pressure to build up inside the housing which would look to get out wherever it could.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
