420C engine clutch throwout spring routing
Greg Hunter
03-28-2001 18:06:37
I am replacing the engine on a 420c, and the clutch throwout spring was broken & half gone. I got a new one from J.D. but am not sure how to install it. I put one end on the bell housing cross bracket horn and route it under the U shaped bracket that is connected to the clutch pedal rod and then hook it to the throwout bearing horn. In this position the spring is pinched by the U bracket when the pedal is released. Is this normal? I have a manual on order but can't wait.
Stacy Rhines (again)
03-28-2001 19:32:13
 Re: 420C engine clutch throwout spring routing in reply to Greg Hunter, 03-28-2001 18:06:37
I can scan pic out of my books, and e-mail them to you, or take a pic of how mine is and send it to you, (the motor is out right now)
Stacy Rhines
03-28-2001 19:29:31
Isn't there 2 of those springs in there ? or am i thinking of the wrong spring, mine is a 440, but I think they are the same, you go from the eyelet on the back of the bellhousing, to the slider for the bearing, one on top, one on bottom.
Greg Hunter
04-01-2001 07:51:43
 Re: Re: 420C engine clutch throwout spring routing in reply to Stacy Rhines, 03-28-2001 19:29:31
Stacy - Thanks for your reply, I finally received my manual and the the foot pedal rod to the throw-out bearing has an adjustment cam that needed to be repositioned to get the U bracket off the spring. The manual does only show one spring. Thanks again.
