IH 500C torque converter??
KURT
03-03-2003 15:10:11
I have a International 500c with a bad torque converter leak. I plan to remove the engine to replace the seal. My question is: Can the converter be tested to see if it needs to be replaced or can it be rebuilt? If I'm going through the trouble to replace the seal what else should be checked to insure that I'm getting ALL the engine power to the drive? Thanks! Kurt
Steve
03-04-2003 09:29:08
 Re: IH 500C torque converter?? in reply to KURT, 03-03-2003 15:10:11
third party image
Kurt: The converters are sealed units. They have to be cut apart and rewelded. If you haven't had any converter related trouble, I wouldn't worry about it. Check the seal surface though. If it is bad you may need to replace it.
