1010c -Oil in coolant
Jamie
03-08-2003 18:11:00
Hello everyone...I have been using my 1010c for snow pushing and it has been working quite well. However I was checking fluid levels before running this weekend and found a little skiff of oil in the radiator. I was able to remove it with a rag, but I am a little concerned as to where it is coming from. Any ideas ?? Thanks Jamie
Lavoy
03-09-2003 18:43:38
 Re: 1010c -Oil in coolant in reply to Jamie, 03-08-2003 18:11:00
Watch your reverser for anti-freeze. The early 1010's have the reverser cooler in the radiator.
Lavoy
clark
03-08-2003 20:39:16
Keep a close eye on the oil in the coolent.. someone may have added some oil to the cooling system to to help keep the seals soft in the water pump. if this isnt the case the only other place it could come from is a bad head gasket.. i wouldnt worry about it unless your getting alot of oil in the radiator or coolent in the oilpan.
