440 IC
Ron
03-10-2003 15:23:12
I have a jd 440 ic and need help. Crawler has a 5 speed trans and reverser. When I release the clutch the transmission grinds, and crawler will not move. I tried to pull it with my Super M and could not move it. Just dug holes with the tractors tires. Depressing clutch or pulling back steering clutches does not help. Really need to get it inside so I can work on it. Any suggestions?
Lavoy
03-10-2003 21:46:57
 Re: 440 IC in reply to Ron, 03-10-2003 15:23:12
Pull the top cover on trans and look inside. If it won't move in any gear, it may be the ring and pinion.
Lavoy
Ron
03-11-2003 05:57:07
 Re: Re: 440 IC in reply to Lavoy, 03-10-2003 21:46:57
I've gotten a few e-mails on this, but so far ring and pinion seems most likely. Is there any way to move the machine?
Lavoy
03-11-2003 07:41:27
 Re: Re: Re: 440 IC in reply to Ron, 03-11-2003 05:57:07
Not that you are going to like. About the only way other than skidding it, is pull both of the pinion gears in the final drives. It is a pain, but can be done. Keep in mind that if you do this, nothing is hooked up anymore, and you have no brakes at all so don't let it get away.
Lavoy
ron
03-11-2003 08:19:36
 Re: Re: Re: Re: 440 IC in reply to Lavoy, 03-11-2003 07:41:27
You're right. I don't like it, but I will probably have to do that. Thanks
Lee Bradley
03-11-2003 10:23:36
 Re: Re: Re: Re: Re: 440 IC in reply to ron, 03-11-2003 08:19:36
Ron,
You should be able to release both steering frictions/clutches and move the machine just don't pull the levers so far that you apply the brakes.
Ron
03-11-2003 11:25:50
 Re: Re: Re: Re: Re: Re: 440 IC in reply to Lee Bradley, 03-11-2003 10:23:36
I tried that and it didn't work.
Lee Bradley
03-11-2003 16:55:10
 Re: Re: Re: Re: Re: Re: Re: 440 IC in reply to Ron, 03-11-2003 11:25:50
Jack it up and put a wood plank under each track and tow it with the M. Good Luck
JD dozer mike
03-22-2003 19:11:12
 Re: Re: Re: Re: Re: Re: Re: Re: 440 IC in reply to Lee Bradley, 03-11-2003 16:55:10
Remove the brake adjuster covers and back the brake bands off so the won't engage, if they are adjusted like mine the brake engages very quickly.
If you back them off alot it may work, worth a try.
