Do older small Cats (ten, 15, 22) have a governer?
Jeff
03-11-2003 20:12:13
Just wondering if they have an engine governer like my IH T6
Thanks, Jeff
Bruce L.
03-12-2003 16:22:38
 Re: Do older small Cats (ten, 15, 22) have a governer? in reply to Jeff, 03-11-2003 20:12:13
Jeff
yes the 10 & 15 small & big are all flatheads & have governers
Bob/Ont
03-11-2003 20:58:30
Yes they do Jeff. The Two Ton has the governor on the end of the overhead camshaft. It controls a butterfly valve in a passage through the center of the head, not in the carb at all.
Later Bob
Jeff
03-11-2003 22:15:04
 Re: Re: Do older small Cats (ten, 15, 22) have a governer? in reply to Bob/Ont, 03-11-2003 20:58:30
Bob, You say the two ton has an overhead cam. Don't the ten and small fifteen have flat head engines?
Jeff
Bob/Ont
03-12-2003 06:35:59
 Re: Re: Re: Do older small Cats (ten, 15, 22) have a governer? in reply to Jeff, 03-11-2003 22:15:04
Jeff the Two Ton built in the twenties had a Hall Scott engine. That engine is a wonder to see. The rocker arms are right angle and mounted on a shaft above the cam. They have large square flaps on the end that ride on the cam and over lap each other. These flaps ride on the cam 90 deg apart and the same lobe opens the intake and exh valve. The engine is also a Hemi Head too. I have only seen a 22 built in the 30's it is OHV.
Later Bob
