Drott 150
Dan Cooper
03-15-2003 06:06:54
I have a Drott IH 150 Crawler with a severe tranny oil leak coming from the bell housing. I tried to investigate without removing the motor and peering through the top cover, but haven't been able to get it started with everthing removed. It only leaks when under power. It has the hydro shift. Anybody else experience this?
Jim
03-15-2003 08:41:34
 Re: Drott 150 in reply to Dan Cooper, 03-15-2003 06:06:54
What you probally have is the IH 150 crawler with the Drott skid shovel attachment. If it is trany oil coming out of the bellhousing you probally have problems in the convertor or the charge pump as the convertor goes into the pump. To do any repairs to either the engine will have to come out of the machine. Convertor could have bad seals or could be cracked, could be drive straps broken and convertor not running straight in charge pump and seal leking.
Dan
03-15-2003 10:30:17
 Re: Re: Drott 150 in reply to Jim, 03-15-2003 08:41:34
Thanks Jim. Your right, it is an IH 150 with a Drott 4-way bucket. I'll quit draggin' my feet and pull the motor.
