420c reverse problems
Steve
03-16-2003 07:05:22
I have a 420c with a 4 speed trans ,the problem is it doesn't want to stay in reverse ,when you put it in reverse it doesn't feel like it is going all the way in (like the other gears).I changed the cover and shifter forks and it is still the same.Nothing seems bent or wore out,is this a problem with the 4 speed trans ,I have a 420c with a 5 speed and it works perfectly.
JD in da UP
03-21-2003 06:16:15
 Re: 420c reverse problems in reply to Steve , 03-16-2003 07:05:22
Hey Steve, What does it do when the machine is stopped, engine off and standing still? Does it feel like it goes in all the way then? Just wondering.
Lavoy
03-16-2003 19:02:20
Steve,
Double check to make sure there is no play in the shafts like a loose bearing. Under load they could be moving. Also check the gear to see of the teeth are tapered. Have seen on that will not stay in 1st, found out the gear was worn tapered.
Lavoy
Jim in Michigan
03-16-2003 15:18:09
I have the 4 speed in mine and have no trouble,,I never use anything other then 2nd and reverse normally though..,I have had it in 1st and 3rd once,, thought it would fly apart in 3rd lol.2nd is fine for me lol..Jim
