1992 Case 580SK 4x4 front axle
Burton
03-27-2003 19:31:57
The lower kingpin in the swivel housing refuses to come out. Would heat to the swivel housing be OK, or is there another removal method that would be better? Thanks in advance for any ideas.
Bud
04-13-2003 20:37:48
 Re: 1992 Case 580SK 4x4 front axle in reply to Burton, 03-27-2003 19:31:57
Mac ....You're right ....they are a b..... Your method worked. Thanks much, Bud
Mac
03-28-2003 12:59:44
It is very difficult to get the pegs out of the Carraro axle when at the factory don't bother to put anti sieze on,you can use heat,steam clean off all grease so there won't be any fire that could burn the seals on the U/J's etc,I use a 36" pipe wrench and a length of scaffold pipe and try and turn them after heating,if you get them to move at all you are on the home run,block up the axle on the side you are working on so it will be held solid
Good Luck
Mac
