JD 350C Hood latches and Exhaust
David
04-01-2003 08:46:33
I want to purchase two hood latches for my JD 350C. Is there someplace where I can purchase these "used' or will I have to buy new ones from John Deere?
I also have a "homemade" exhaust system made from welded pipe that connects to the exhaust manifold. It doesn't seal well at all. Does anyone know where I might buy a used one? Thanks in advance for any help.
David
Ric
04-02-2003 14:36:28
 Re: JD 350C Hood latches and Exhaust in reply to David, 04-01-2003 08:46:33
I went to the hardware store, bought bolts and springs to make my own. Works great and was cheap. I found owning a dozer, one needs to be able to do this kind of thing because it seems to be ongoing.
Daniel
04-01-2003 10:35:53
A friend of mine had a similiar problem with the exhaust with a older 40C he bought...The welded pipe assembly was just resting on the flange that comes off the manifold. It was pretty rusty also. We cut the exhaust pipe with a pipe cutter, made several 3" cuts up the pipe, i think we made 6 or 8. put this onto the flange, and clamped it with two stainless clamps from Home Depot. Sure its not factory, but it now works fine and was a cheap fix.
