Fuel line fix
Doug Rogers
04-03-2003 06:02:45
I have an older Allis HD6 crawler that has a leaking fuel line(diesel). I believe the line is copper. I believe that the line has worn throught due to years of vibration against the frame. I can get to the leaking spot but I can;t get to the connections to take the entire line off without tearing into the underside of the machine. Is there some way to patch this line without taking it off? I thought about a hose clamp with rubber gasket but was afraid the diesel would disolve the rubber. Any suggestions out there? The leak is under the seat which I can easily take off and access but not much room to maneuver. Thanks in advance.
gm
04-03-2003 17:37:12
 Re: fuel line fix in reply to Doug Rogers, 04-03-2003 06:02:45
I'd say cut the section out and replace
with rubber fuel line, clamps on either end.
-Greg
Bob/Ont
04-03-2003 06:38:02
Doug, clean the line good with emeryclothe, cut it and put in a double compression fitting. The best would be the ones that cat use with rubber in them but a regular one with a brass furrel would work.
Later Bob
