350B drain bolt location -final drives
mike in NY
04-04-2003 12:42:13
Mentioned previously here was that there are "drain bolts" for each side of the final. I do not see these anywhere. Are they in fact on each side and hidden by a rock guard or the sprockets ?
fasteddy in ny
04-04-2003 16:34:03
 Re: 350B drain bolt location -final drives in reply to mike in NY, 04-04-2003 12:42:13
Mike, I'm not sure but I'm guessing they are on the inside bottom of each final. They should be a plug that you use a 3/8 ratchet on , like on a car diff. . Hope I'm not steering you wrong. Good luck, Fasteddy
bob
04-05-2003 16:21:26
 Re: Re: 350B drain bolt location -final drives in reply to fasteddy in ny, 04-04-2003 16:34:03
Your right. Get to them underneath, above the belly pan.
