350B Fill plugs 3030 lube
mike in NY
04-05-2003 06:26:00
Drained my finals and the steering clutch housings. Where do I find the Fill plug for the finals? or do I remove the 3 bolt cover and add the fluid there ?
What is the equivalent of JD 3030 final lube?
It doesn't have the tradional GEAR oil smell...
Slowly but surely the beast will run again !
fasteddy in ny
04-05-2003 17:28:48
 Re: 350B Fill plugs 3030 lube in reply to mike in NY, 04-05-2003 06:26:00
Mike , There should be fill plug on inside of each final up a few from bottom . I went to local deere dealer (leberge& Curtis) here in canton a few years back and got a service manual for my 1010. Best thing I did , about 60.00.Forgot to put inches up above after few . I'm a one finger typer so I'm not changing it !!!! Good luck!
fasteddy
04-06-2003 17:00:09
 Re: Re: 350B Fill plugs 3030 lube in reply to fasteddy in ny, 04-05-2003 17:28:48
Mike, I checked my book on the 1010 which is the same chasis as the old 350's and it calls for jd303 or 80wt.
