1981 td7 steering
jim collins
04-07-2003 11:36:25
I just bought a 1981 td7 dresser i have used it about 15 hours since i got it .when i went to buy it you could pull on the levers and it would turn on a dime then one day i went to get on it and it would hardly do anything unless you come to low idle or step on brake padal in floor . just wonder were if any one could give me some advice. also were can i get a service manual and parts manual at. dozer has good undercaiage and runs excelent it also steared real good untill the other day. almost acts like it dont get preasure through the valves all the time.
Ray
04-08-2003 19:55:47
 Re: 1981 td7 steering in reply to jim collins , 04-07-2003 11:36:25
Jim, There Is an adjustment screw on both side of tractor at top front corner of final drive housings, just below hdy tank on right side, on the left it is below the battery box. It has a screwdriver slot in the end of it. you loosen the lock nut and turn the screw in or clockwise just a little then tighten lock nut up. If it sounds like metal against metal you need new lining on your streeing brakes. I can supply you with Relined Exchanged brake shoes, also the manuals you need. Thanks, Ray snydereq@sky-access.com or 1-877-901-5556
