Case D450 Upper Roller
Ric
04-08-2003 11:24:34
I have a 1970 Case D450 that the upper roller is sloppy in the mount. It has all new rollers, track and such at this time. I suspect that someone used with worn out roller and it oblonged the hole. It allows the roler to tip down about 1/4 inch on the outside edge. Can this simply be welded up and ground back down to fit properly?
Thanks
marlowe
04-08-2003 13:27:36
 Re: Case D450 Upper Roller in reply to Ric, 04-08-2003 11:24:34
is the roller loose on the shaft ? or the shaft loose in the holder? if roller loose on shaft check your bearings. if loose in holder you might have to replace the shaft or build it up [a little over size] if hole in holder is worn then you got trouble. is the bolt to tighen the the shaft in the holder good.
Ric
04-09-2003 03:44:25
 Re: Re: Case D450 Upper Roller in reply to marlowe, 04-08-2003 13:27:36
The complete bearing assy is new. The shaft is lose in the holder because the hole in the holder is oblonged. That is why I was wondering if that could be built up by welding.
