Hyd. getting weak after 1 hr of use?
chuck
04-04-2001 16:11:38
MY hydraulics get weak after a hour or so of use
I know motor oil pressure will drop after a engine
gets warm so I guess my hydraulic pressure is dropping as it
heats up. When I got the loader I changed out the fluid &
put in cheap hyd. fluid from auto supply chain
store.I wander if changing it out & buying a more
expensive fluid would help any?
jerry Gerthofer
04-06-2001 11:29:28
 Re: hyd. getting weak after 1 hr of use? in reply to chuck, 04-04-2001 16:11:38
Im,e sure it's not your oil. think your pump is getting weak. needs rebuilding
drott
04-04-2001 21:07:21
Heat can affect oil, and some older dozers used straight 30 wt for the oil. Also has things heat up in the machine you might find that expansion in the hydraulic pump is causing it to lose presure. The tollerance in the gear driven pumps is very minute and any changes in there can have big effects on the how well things work.
First place to look is the oil, Second is the pump and the last are the cylinders.
marlowe
04-04-2001 18:57:22
heat will have a big affect on hyd. oil and you might have to light of oil plus you get what you pay for!
corey
12-10-2001 19:55:06
 Re: Re: hyd. getting weak after 1 hr of use? in reply to marlowe, 04-04-2001 18:57:22
Good chance your pump is shot-heating up and allowing to much clearance in pump
