D6C Cat Question
Roger Barnes
04-14-2003 09:42:02
I just purchased a D6C Cat, it has a coolant leak, and I took the bottom skid plat off, to inspect and clean, and the coolant is running out from behind the waterpump. Is it possible to remove the waterpump without removing the radiator first? I don't know if it's busted, cracked, or just the gasket, I can't tell until I get it off.
I just don't want to remove the radiator if I don't need to.
Bob/Ont
04-14-2003 10:31:16
 Re: D6C Cat Question in reply to Roger Barnes, 04-14-2003 09:42:02
Yes you can get it off without taking the rad out. There are a few different engines in the D6C though and the pumps are all different. Is yours behind the fan or at the side?
Later Bob
Roger Barnes
04-14-2003 10:39:52
 Re: Re: D6C Cat Question in reply to Bob/Ont, 04-14-2003 10:31:16
It's offset to the fan (side). It's not directly behind the fan, like a car or something.
It just didn't look like there was room to drop it out the bottom or to bring it up from the top, but it might clear after I get it un-bolted.
I sure don't want to remove the radiator, unless I absolutely have to.
This is in a 1975 model, D6C 10K. I didn't specify that early, sorry.
Any info is appreciated.
Bob/Ont
04-14-2003 10:55:24
 Re: Re: Re: D6C Cat Question in reply to Roger Barnes, 04-14-2003 10:39:52
Rodger, sounds like the face seal is leaking behind the impeller. Taking off the fan guard might help you a bit.
Later Bob
Roger Barnes
04-14-2003 10:59:34
 Re: Re: Re: Re: D6C Cat Question in reply to Bob/Ont, 04-14-2003 10:55:24
If I remove the fan guard, it might clear. If it's possible to get it out with removing the rad, I'll get it done.
Thanks for sharing your knowledge on the topic.
Bob/Ont
04-14-2003 13:29:07
 Re: Re: Re: Re: Re: D6C Cat Question in reply to Roger Barnes, 04-14-2003 10:59:34
Rodger, I think if you get the hoses off it will unbolt from the top of the drive gear housing and come up towards you.
Later Bob
Dave N
04-14-2003 14:37:12
 Re: Re: Re: Re: Re: Re: D6C Cat Question in reply to Bob/Ont, 04-14-2003 13:29:07
Take the 2 long bolts out the front cover. Take the 2 bolts out of the elbow on the ffont of the head loosen the hoses it should pull out 1.5 to 2 inches and comr out at the most you should have to remove the fan guard. The kits are inexpensive to rebuild the pump and you dont need a press or special tools. Dave
NGUYEN V TAN
06-24-2003 19:07:36
 Re: Re: Re: Re: Re: Re: Re: D6C Cat Question in reply to Dave N, 04-14-2003 14:37:12
We are looking to buy after market reproduction of CAT PARTS,for replaces we wonder if you carry this businessif you do we will send you the CAT MODEL and serious number, price FOB to VIETNAM.
Sincerly NMguyen
