JD 310-A out of diesel fuel
peckspa
04-16-2003 17:40:50
I just bought a JD 310-A backhoe at auction. As soon as the driver unloaded it off the trailer it ran out of fuel. I'm new to diesel engines. Could someone tell me how to get it started again? Please explain the procedure so I can understand the different parts involved.
Thanks for any help.
Jonathan
04-16-2003 22:04:43
 Re: JD 310-A out of diesel fuel in reply to peckspa, 04-16-2003 17:40:50
..ummmm....put some fuel in it !!! ....then...on the right hand side of the engine (sitting in the seat)... there is a transfer pump...on the side of the transfer pump there should be a small lever...also on the right side there should be a fuel filter...either you have a rectangular glass type filter or a round metal filter with a glass bowl on the bottom....if you have the rectangular glass filter there will be a bleed screw (9/16 wrench will fit) on the right of the filter base....loosen it a few turns...if it is the cylindrical metal filter, there will be a bleed screw on top....loosen it....pump that lever on the side of the transfer pump until fuel pumps out nearly getting you square in the eye !!...at that point , tighten the bleed screw...then on the opposite side of the engine at the injection pump, find the line that feeds the pump from the filter...It should enter the pump at a 90 degree fitting on the rear of the pump...loosen the fitting and again pump that lever until fuel leaks from it.... then tighten...pump the lever a few more times and try to start it....it may take a little cranking ...hopefully the batteries are up to it....should start without bleeding the injectors....also...before all this....it might be a good time to install a new fuel filter...
