A grease gun and greasing question JD 450
John
04-17-2003 08:03:04
The service manual says that a special grease gun should be used on the track rollers. Is that really true? Do you guys use regular grease guns?
Is there a special ending for those slot headed fittings? Where can I get one? Nearest dealer is 100 miles from here...!
Don
04-18-2003 14:55:29
 Re: A grease gun and greasing question JD 450 in reply to John, 04-17-2003 08:03:04
You can get the button head for your grease gun at NAPPA auto parts store when you grease the rollers only pump till you feel a little resistance then stop or you will blow out the seals should have no prob with a regular gun.
Good Luck Don
Tim
04-18-2003 05:03:47
My JD manual says that the special grease gun also limits the pressure to I think 5 psi so that you don't blow out the seals. I am sure you could put in a pressure guage in the line and keep your eye on it.
H-3 Fan
04-17-2003 11:59:58
Their called Button head grease fittings and some parts stores sell them. I know that you can buy them at NAPA because I have. You can get the buttons in to different sizes and the fitting for the gun it self. Their not cheap, plan on around $20.00 could be alittle more or less.
Have a great day,
Tim in Oregon
04-17-2003 11:42:49
yes there is a special fitting for your gun, I got mine at a local auto parts store...
