Austin Western Motor Grader
Joel
04-20-2003 17:32:10
I just purchased an Austin Western Motor grader it is a 4 wheeled model with 4 wheel drive and 4 wheel steer, a 12 foot MB, 3 speed trans with hi-lo and a detroit 4-71 engine. Anyone know what model this may be? Where I can get parts? Any information would be appreciated
Kelly
04-21-2003 01:16:56
 Re: Austin Western Motor Grader in reply to Joel, 04-20-2003 17:32:10
Joel, From what you have said about your Austin-Western, and the information I have, I would say with the GM 4-71 diesel engine you may have a Model 99L , Model 300 Pacer, Model 400 Pacer or a Model 400 Pacer Senior they all had the GM 4-71 engine according to my information , were single rear axle, all wheel drive, it all depends on the year it was manufactured . if you had a S/N one could get this closer. The SN on the Austin-Western should be on a plate… left side of the frame, far forward. Also stamped in top front of the frame.Hope this helps alittle.
Joel
04-23-2003 03:18:24
 Re: Re: Austin Western Motor Grader in reply to Kelly, 04-21-2003 01:16:56
I found the serial number under several layers of paint, H2770. Any Idea what the model is, how about weight?
Thanks Joel
Tom Graham
04-21-2003 16:12:03
Joel, I have several manuals for AW graders. Let me know what model you have and I'll see what I have.
Frank Lipera
10-03-2003 13:50:22
 Re: Re: Re: Austin Western Motor Grader in reply to Tom Graham, 04-21-2003 16:12:03
I have an AW #77 Motor Grader Senior. Do you have any manuals or info on this one?
jmoore
04-25-2003 18:03:30
Tom,
What manuals do you have for a Austwin Western Master 99H?
Joel
