450 JD Transmission Trouble and Year?
Quinten
04-24-2003 18:40:19
Trying to find out what is wrong with a JD 450b w/ H-L-R. It pushes good forward but seems to be a slight lag in reverse when it gets hot though it still will move in reverse. Also it does not move unless you are at pretty much full throttle, is this normal? I would like to know the year, serial no. is SNT553M013132T. Would also like to know where to find pins and bushings for the sixway blade.
Keith
05-29-2003 07:57:54
 Re: 450 JD Transmission Trouble and Year? in reply to Quinten, 04-24-2003 18:40:19
Did you get any info on the JD 450B transmission. I am looking at buying one myself and would like to know about it before I jump in. I have a feeling it is hydraulic though and you probably have some internal seal leakage. Someone that can pressure test it would more than likely be able to tell you for sure. Also if you have any info on specs, I would like to know. Thanks, Keith Miller
