JD 440 trackloader serial #
TimV
04-30-2003 17:57:49
Howdy all--looking at a 440 trackloader, with a serial number of 448714. I couldn't find a listing for the 440 in the serial page on this site, and wondered if anyone would have any info. It's a gas engine, if that helps.
Lavoy
05-01-2003 09:25:15
 Re: JD 440 trackloader serial # in reply to TimV, 04-30-2003 17:57:49
Tim,
It is a 1959. There are some pictures of 440's on our website if you want to see some more.
lavoy
TimV
05-01-2003 09:42:31
 Re: Re: JD 440 trackloader serial # in reply to Lavoy, 05-01-2003 09:25:15
Thanks, Lavoy--I kind of figured you'd know the answer, but didn't want to bug you personally. I had already looked at your website (very nice by the way), but wasn't having much luck finding a 440 serial listing. Is there anything I should know about or check on this crawler before making an offer? The grousers appear to be nearly flat, or perhaps they were a less-agressive "tread" to begin with--it's hard to tell. Other than that, everything seems to be there, but I haven't heard it run or saw it move yet, and haven't called the owner--I just gave it a quick walk-around as it was raining the day I stopped.
Brandon
05-02-2003 20:37:28
 Re: Re: Re: JD 440 trackloader serial # in reply to TimV, 05-01-2003 09:42:31
I have an industrial JD website, and have the serial number ranges for the 440 listed, along with some other info. Your tracks might have "street shoes" on them, which are pretty much flat. Can't help you much other than that, good luck!
My John Deere 440 page
Brandon
Lavoy
05-01-2003 20:57:41
Check the tops of the finals to see if they have been blown out. Check the 4 large bolts that hold the center section between the engine and trans together to see if loose or missing.
It could have easily had semi-grousers, very common on loaders. Look for cracks and welds.
Lavoy
