D2 CAT FUEL SYSTEM
Roy Davies
05-01-2003 20:49:55
I just bought this cat this week and the fuel injector pump assemblies are stuck up and will not operate. Has this happened to any one and what was done to correct the problem? Also the fuel pump is building no pressure on the fuel pressure gage, is this due to the same problem or is something else going on here also?
Thanks for the help.
hector gemme
02-10-2005 15:23:43
 Re: D2 CAT FUEL SYSTEM in reply to Roy Davies, 05-01-2003 20:49:55
HI I HAVE SOME D2 USE PARTS
John Lee
02-23-2005 16:25:38
 Re: D2 CAT FUEL SYSTEM in reply to hector gemme, 02-10-2005 15:23:43
I will take them
chrisser
05-10-2003 14:21:01
The transfer pump feeds the injector pumps. The gauge is between the transfer pump and the injector pumps so I would say the problem is not related and you only have a fuel delivery problem. (This is a good thing)
Chrisser
05-10-2003 14:16:43
A couple of thoughts. The cover easily comes off the transfer pump. Are the gears turning? Is the shutoff at the bottom of the fuel tank on? It is a fairly large filter cavity. The top comes off easy. Is it full of fuel? Is the bleed screw shut? The injector pumps - Is the linkage past the off detent that is at 1/4 to 1/3 total linkage travel? Good Luck
steve
05-03-2003 17:36:59
Try acmoc.org antique cat owners club They can help if anyone can and a better bunch can't be found
