JD 310 serial numbers
Paul
05-13-2003 12:31:32
Hello,
These are some numbers I found on the tractor and on the backhoe.
Tractor block : R5511D
Backhoe: 115804 T53970
Would anyone know what these numbers mean and if they are not the serial number where do I look for the serial number.
Thanks,
Paul
Mike
05-13-2003 13:28:13
 Re: JD 310 serial numbers in reply to Paul, 05-13-2003 12:31:32
The tractor serial number is on a plate on the frame by the right front wheel. If the plate is gone the numbers should be stamped in the frame in the same place.
paul
05-13-2003 13:59:09
 Re: Re: JD 310 serial numbers in reply to Mike, 05-13-2003 13:28:13
Mike,
Thanks, I will check it out.
Paul
