Continental ? Engine???Please Help me ID this thing.
Jim B
05-15-2003 15:34:59
Cleaning out Dad's Grainary and found a crated 4 cyl flathead with no data plate. Block casting # F400A-613. Head casting # 4E23 next to firing order 1342. Governor in front housing, RH side. Distributor mounts dead center. Any Ideas? Thanx.
emanarias
06-16-2003 02:32:09
 Re: Continental ? Engine???Please Help me ID this in reply to Jim B, 05-15-2003 15:34:59
its the same engine i have in a 1966 Navy surplus truck that i am restoring. the plaque reads:
CONTINENTAL MOTOR COR'N
Model:F4162 Spec:427
if you would like any more specs on it, i'd be happy to pass them on as i get them.
Jim B.
05-29-2003 15:08:47
Anybody else have any Ideas? Please help.
TOm Cone
06-16-2007 11:50:43
 Re: Re: Continental ? Engine???Please Help me ID this in reply to Jim B., 05-29-2003 15:08:47
The numbers on mine are F400a-612. 0 1 and CWC. EL. I too need parts and a replacement short or long block if you have any leads.
Jim B.
05-17-2003 20:01:04
 Re: Continental ? Engine???Please Help me ID this thing. in reply to Jim B, 05-15-2003 15:34:59
Thanks Gents, I'll take another look and see what other numbers I find. I'd sure like to narrow it down to 2 possibles soon.
r_d97
05-16-2003 06:19:25
The F400A block sounds like it could be a Continental F124, F140 or F162 engine. The F124 was likely the most common engine. My F140 has the number embossed in the head though. Continental also put the numbers down by the oil pan on the block. I think it was on the right side.
Edward
JERRY-L.I.-N.Y.
06-05-2003 23:18:55
 Re: Re: Continental ? Engine???Please Help me ID t in reply to r_d97, 05-16-2003 06:19:25
My Thompson parts man. shows CONT.F4124 124 cu.in.
F4140 140 cu.in.,16.3 hp. ----- ----- -- F4162 162 " " 18.9 "
Hope this helps
Jerry
bob
05-17-2003 08:46:56
 Re: Re: Continental ? Engine???Please Help me ID this thing. in reply to r_d97, 05-16-2003 06:19:25
Hercules put their motor # on the oil dipstick. Thus when you pull out the dipstick in an Oliver OC3, you will see IXB3 stamped on it. Wish other mfrs. would do that.
