CASE 1150E MANUALS
MIKE
05-19-2003 17:16:48
I have a 1150E dozer and i am having trans. pressure problems. I need a service manual and a parts manual for this dozer. also where can i find a trans. charge pump?
Galen
02-03-2004 17:23:03
 Re: CASE 1150E MANUALS in reply to MIKE, 05-19-2003 17:16:48
Mike, wondering if you found out why you had low trans pressure? Having the same problem on the same dozer, I have done replaced the charge pump, it helped a little but not enough, wondering if you had any input. Thanks Galen
MDL
02-24-2004 19:15:24
 Re: Re: CASE 1150E MANUALS in reply to Galen, 02-03-2004 17:23:03
Transmission preasure problem is most likely from blown gasket in trnsmission control valve below seat.
