JD 450 brake replacement
Chip Allard
05-22-2003 05:18:48
Does anyone know if you can replace the brake shoes on the steering clutch housing without taking the entire assembly out of the machine?. Can they be disconnected and slid around so you can get them out the top????
Lavoy
05-22-2003 09:16:42
 Re: JD 450 brake replacement in reply to Chip Allard, 05-22-2003 05:18:48
Chip,
You should be able to remove the entire clutch assembly and brake from the top. I think you will find that you need to remove the seat/battery box/fuel tank for easier access.
Lavoy
Bob
05-22-2003 12:20:24
 Re: Re: JD 450 brake replacement in reply to Lavoy, 05-22-2003 09:16:42
You can remove the brake band without removing the clutch. To remove the clutch you must break the track and remove the final drive pinion first.
