International T340 crawler
William
04-12-2001 13:47:45
Where is the serial number plate on the T340 crawler?
Sam
04-14-2001 04:47:07
 Re: International T340 crawler in reply to William, 04-12-2001 13:47:45
The serial number plate is located on the right hand side of the clutch housing, just below the voltage regulator, or just behind the oil filter housing.
The tractor serial number is also stamped on the rear side of the transmission housing at the upper left. The numerals are large - about 3/8" high, with shallow stamping depth, which makes them very hard to find.
Stan VanGorder
05-06-2005 06:20:32
 Re: Re: International T340 crawler in reply to Sam, 04-14-2001 04:47:07
I recently bought a International T340 crawler. It starts hard. Do you have any recommendations to make it start easier? Would converting it to 12 volt help? Thank you, Stan
