J.D.350B Track Adjusting cylinder
Dick
06-02-2003 16:03:01
Fisrt I would like to thank Lavoy for information on brake replacement.When working on track carriar roller,I released tension on track by removing set screw&nut next to grease fitting,when trying to tighten track back up Grease comes out little hole in front botton of cylinder about 3-16 round, I notice in parts manual a little ball goes under set screw. I did have screw out,but never seen little ball.Any help would be appreciated. Thanks Dick
Brokenwrench
06-02-2003 17:46:59
 Re: J.D.350B Track Adjusting cylinder in reply to Dick, 06-02-2003 16:03:01
You will have to replace the ball. The screw pushes down on the ball to seal the leakoff hole. You should have just loosened the screw 2 or 3 turns to release pressure. Who knows, you might be lucky enough to find the ball in the grease that was pushed out.
