JD 350B pulls to one side
Oli
06-15-2003 09:42:06
My JD 350b pulls to the right on normal terrain. Any ideas why?
jdemaris
06-16-2003 06:03:28
 Re: JD 350B pulls to one side in reply to Oli, 06-15-2003 09:42:06
There are lots of things that can cause the problem. However, if you feel that nothing is dragging, something as subtle as uneven length tracks can cause it. I've worked on several crawlers where just one track was pin and bushed (or had the pins and bushings turned)instead of doing both sides at once. Invariably, such a machine would not drive in a straight line.
Oli
06-26-2003 09:40:28
 Re: Re: JD 350B pulls to one side in reply to jdemaris, 06-16-2003 06:03:28
Thanks. You're right on the money, because one track was repinned and bushed. This is not a serious problem since I am just a hobbiest, but I like to know and also improve my equipment rather that run it into the ground.
At what point should the other side be done? Also the sprockets are worn and wonder if replacement is advised.
captain,nemo
06-19-2003 07:38:57
I think you just hit on what is going on with my HD5 AC Everything looks the same on both sides.But it has always turned right,about
1 O'clock in a hundred yards. Thre left track adjuster is ran out farther than the right one.
